Have several lights on dashboard on. Most concerning is a red, blinking "PARK" when electric parking break is engaged/disengaged. The green indicator around speedometer is not working either.
In a forum that people who have a problem with their car will gravitate towards, you are going to hear about problems. Huge masses of Honda owners that have not had a single problem by and large will not be in this forum.This is horrible. As much as I like Honda, all of these posts regarding several different models having issues is making me think twice about them. That Celaya plant needs needs to get it's **** together.
It only took you 2 years to reply to my post? HeheIn a forum that people who have a problem with their car will gravitate towards, you are going to hear about problems. Huge masses of Honda owners that have not had a single problem by and large will not be in this forum.
I am an exception and not part of a SILENT and satisfied majority as I joined HRVForum as an HRV enthusiast. Have 17k on a 2016 without a single problem or even an annoying noise.
Don
What he said! I love my HRV.In a forum that people who have a problem with their car will gravitate towards, you are going to hear about problems. Huge masses of Honda owners that have not had a single problem by and large will not be in this forum.
Don
I had this problem on my HRV. The Red Brake light flashing and yellow Park Brake and check ENG light. The problem is caused by a low voltage from the battery. I had mine checked and even though it the car would start the voltage was low. I bought a new battery, all the lights are out now and works fine.Took mine back to dealer with the same problem. They said it was a voltage problem from the battery allegedly draining on the lot. They cleared the code from the computer, then retested, but no error codes came up so it seemed it was fixed. Now a day later the same warning lights as posted above are all back on and the car is going back to the service department tomorrow; I have not even owned it a week. I have owned three great Hondas in my time but could not be more disappointed with the apparent lack of quality control here.
i have the same issue, any updates ,what you do ?I had this problem on my HRV. The Red Brake light flashing and yellow Park Brake and check ENG light. The problem is caused by a low voltage from the battery. I had mine checked and even though it the car would start the voltage was low. I bought a new battery, all the lights are out now and works fine.
same issue what happen next did they fix it ?Same problem. Day 3 of owning car. It has sat for 4 days in the dealer service department. Not thrilled at this point.
He explains his problem there.The problem is caused by a low voltage from the battery. I had mine checked and even though it the car would start the voltage was low. I bought a new battery, all the lights are out now and works fine.
Yes replace your battery. Clearing the code will not fix the problem. The problem is a the low battery voltage. I left mine on the charger overnight and still had the problem. The next day I put in a new battery, the code cleared automatically and problem is gone.i have the same issue, any updates ,what you do ?
I also have the same problem with yours. I will try to change the battery and see how.I had this problem on my HRV. The Red Brake light flashing and yellow Park Brake and check ENG light. The problem is caused by a low voltage from the battery. I had mine checked and even though it the car would start the voltage was low. I bought a new battery, all the lights are out now and works fine.
